Hi Greg,
Had to go get provisions for the lap dogs
, 180 pounds worth of dry food and two flats of wet
. I figured you'd appreciate this Greg
Those four GSD's like to eat good hahah. I have to make this run every six weeks. As far as the waste, well its around 30#'s a week
(TMI!!!)
Anyway, Thanks for getting back to me. Yes, this magnetic scales are compact with only .375" of protrusion. When you ask "compound to the bed" I'm assuming parallel to the bed (forgive my ignorance). If this is what you mean, Yes, all sorts of room.
The first photo shows the cross feed travel all the way forward. Plenty of room left for the carriage towards the head stock but the long scale is sticking past at the moment.
In this shot the cross feed is in with plenty more room to go inboard. I had to stop there as the extra long scale (sticking out towards the chuck) had not been cut yet and will contact the chuck. I plan on using a CXA QCTP, that should give me more clearance when arranged the same way you have yours.
On my 1440, I have been threading with the compound at 90º for years since I use robust threading inserts. The 29.5º was the way I learned in HS, but discontinued this some years back with excellent threading results using only the cross feed.
I'll get the scale cut to size and see how close to the tailstock it will get.
Thanks again for your input. I'll have my phone to monitor any other questions or recommendations for the compound scale mount.
Paco
