Well fellas, after a long day we simply ran out of time. I had to move back other equipment after locating the lathe. I still need to level her out before I can make chips but we hit a couple of minor snags. The tach pickup need to be modified. It seems the balance collar is slightly magnetized although I'm inclined to think the multiple threaded holes around the circumference 12 total (for balancing ) have something to do with the erratic pickup. The second issue is yet to be confirmed, but we suspect a bad 3 pole breaker (3Ph) that feeds the Dc power supply and the 240vac 3 ph flood pump where we pulled 110 to supply power for the hardwired DRO. The lathe was running great with everything working as it should with the exception of the tach but foam strips and electrical tape allowed us to make it work for now (insulator). Then without warning, everything went dark except the VFD. The 24vdc led's, the 110vacDRO and the rest of the control system relies on 24vdc. The 3 pole breaker that supplies juice to the said components is a Siemens so not junk but things happen. I will conform bad breaker tomorrow and get the machine level. Wait for new part and start test cuts ASAP. Mark was able to auto tune the VFD to the motor via laptop prior to the power loss.
The wall enclosure. Top left: AC Choke, three pole 240v 3ph breaker (possible problem), through cover disconnect, VFD, fuse blocks and DC power supply. The brake resistor can be seen behind the fuse blocks and breaker. The cooling fan also runs from the dc power supply.
How she looked running, impressively quiet at 1200 RPM.
How she sits DIW. She looks right at home.
When I think of the amount of work that went into this and all the replacement components a couple of snags are minor nuisances.
Mark really knows his stuff, he's super helpful and generous.
Stay tuned guys, I'm now without a working lathe so It will be top priority to get her operational ASAP, then we can begin the performance evaluation.
Take care,
Paco
