My mount, for the mitre gear, was broken and I found the assembly on ebay with the spine gone. ($29) But fortunately my mitre gear spline is good and all I wanted was the mount. It's crazy money what eBayers want for a good assembly!
Yup that happened to me also. When it crashed the mitre gear striped inside and cracked and broke off the whole mount. Got lucky and found another whole assembly. Make sure to see if you need shims behind the mitre gear mount for mesh clearance. Don't want any binding between the two gears or it will happen again. I made my own with shim stock and trimmed off the top so oil can flow to it. (Not shown)
Mine is also missing the keyway on the piece that rides thru the leadscrew. So...I made a new one. Took a couple tries as I eventually figured out the printer was .01" smaller in diameter than the CAD output.
