- Nov 27, 2012
- 7,970
I like the way yours turned out. One question, on the thread on the handle where you changed from 3/8" thread to the M10, how did you make it longer? Did you drill and tap the handle and then make a threaed insert to thread in which protruded out further than the original or some other way? Just curious.
Thanks Mike.
Sorry, I guess I should have taken more pics & explained better on that part.
3/8" major is .375" & M10 is .392" so that was obviously the issue....
First I turned down the 3/8-16 thread to a dia smaller than the M10x1.5 minor.
Then I made a new sleeve/slug & pressed it onto the turned down stud using an arbor press. I machined a few small shallow grooves on the shaft & added some red Loctite for good measure (I didn't have any purpose specific anerobic adhesive but threadlock has always worked fine for me in the past which is an anerobic adhesive anyway).
If you look closely at the base of the stud & compare to the pic above you can see the slug is a larger dia.
Then I turned down the new slug to the dia I needed for the M10 thread & single pointed the thread.
OK, so now you're making me feel bad for not machining the back of the wheels. Well maybe not... :lmao:
I too was thinking of painting the insides of the wheels black. To match my mill.
So, the final test: Do you like the feel of them over the plastic thingies?
My stock table handwheels attach with both using a center bolt & a set screw on the side. I decided to ditch the set screw & use the center bolt only so I needed the spline drive. Well I'm anal like that so I would have done it anyway.
A couple of guys have said not to paint it already. I really wanted to paint the centers black but then again the paint might wear off over time from my hands (the crenelated part is what I'm worried about). Plus it's chrome plated, paint does not like to stick to chrome but then again the area I would be painting has the sand cast finish. Maybe I'll just leave it or maybe I'll powder coat the centers later (I have a hook up through a friend).
But yes, I like the CI handwheels, anything metal is better than the stock bakelite handwheels that I wanted to replace since day one (the first pair of handwheels arrived chipped with the mill & so did the second replacement). Even though my quill fine feed handwheel was metal, I like the feel of the open CI handwheel much better. Thanks again for the idea that finally pushed me to replace them.
