Since it turned out to be a relatively easy job, I installed the limit switch for the mill today so the feed install is now complete.
After removing the center limit block from the table, I took the factory switch plate and made it flat, cut some of the top off and then drilled and tapped new holes for the switch box.
The feed kit has spring-loaded stops to protect the switch box from over-travel but they are large and unnecessary with this small mill. In the picture I ran the table into the limit switch at full balls-out speed and there is still travel in the switch. Also, the table has overtravel stops that work against the knee so if you set the adjustable limit stops correctly, when the switch bottoms-out the table overtravel stop will help save the switch box.
Actually got to make some chips with the mill today and I really enjoyed having the power feed. It's a labor saver and a really nice upgrade.
Very nicely done!
Wally
