Looks like it could come in handy for something. You should call the guy you bought it from and ask him what it is or what it was for.
Put it on there and see if it becomes obvious.Okay... details on the mystery piece...
Dimensions: 1-5/8"x4-3/8"x12-1/8"
Setup to be place instead of the carriage/cross slide. Has adjusters for the gib and a nut to be able to move in and out once installed...
View attachment 414363View attachment 414364
Ahhhh true… I just did not wanted to alter the looks of the lathe…well… looks like I will I do a VFD after all… All of you are just bad influence!You can still change belts if you have variable speed. But you can’t get between speeds with single phase….
Will you have a separate workshop for wood?
