- Dec 18, 2019
- 7,648
I'm not sure. And I'm having a lot of trouble thinking it through. Geometry wasn't my strength.I don't have an ELS, but I think you could do a multi start thread by setting the lead screw TPI to (whatever TPI you want to measure on the final part) / (the number of leads). Then, use the half nut like always, cut one of the leads, then advance the compound by the pitch amount (1/(the final TPI)) and cut another lead.
This automatically clocks the start of each lead appropriately.
Doesn't this work?
If you clock the spindle, it would work, and I think if you advance the lead screw. I'd guess moving the compound might work, but you would have to back off in X to prevent the thread from getting too deep. Moving the compound moves you both in X and Z. Unfortunately I do not have a DRO or angle measurement for the compound, only Z and X on the saddle. Basically, I really don't know the position of the compound that well - the compound lead screw has a lot of back lash. But, it could work, I think. I could try it out without writing a single line of code, that's a plus!
