- Nov 14, 2016
- 3,340
It is a lot to absorb when we are just trying not to grind our finger tips.
I run across a lot of comments about HSS being useful not just as an economical tool, but also for the ability to grind the custom tool you need which may not exist unless you make it yourself.
It is rather hard to make your own tool without understanding what it is that each cut does. At least for myself it isn't that I couldn't care less how it works so much as I'm still trying to figure out what is my fault and which is because of the tool. So many variables between feed rate, depth of cut, angle of the tool, material etc.
As far as a lack of discussion I suspect it is more being overwhelmed and not having anything to add than a lack of interest.
It might help to talk about evaluating a cut to figure out what is going on. To be honest I'm just guessing when a part isn't turning out how I hoped. I'll adjust RPM, try adding some lubricant and adjust the depth of cut, sometimes that works sometimes I finish the piece with a fine and sand paper.
