- Dec 20, 2012
- 9,422
Thanks so much for your response Mike. I really appreciate the time, effort and knowledge you have put into this thread and with guiding me. I've only been at this hobby machining for a couple of years, on a part time basis and it seems like the more I learn, the more I discover how little I know. I've struggled with finishes and getting to target depth for quite a while. Sometimes it seems to come together but I don't know why and most times I just accept the less than great finish and the close enough size. I have found that with this grind I get a far superior finish and it is waaaay easier to hit the target size. Also, very importantly, it is consistent, even for me. The only way I could get a decent finish with mild steel before was to use a shear tool with a very small DOC (0.001" or 0.002") and the slowest feed rate. Now I get better finishes consistently and I don't have to sneak up on the final size with a bunch of very small shear cuts.
I'm glad to hear the long strings are normal and will not concern myself with that when taking roughing cuts.
I'll take a closer look at my honing, especially the top surface, as that is where I think I may not be getting the finish right.
You're welcome, HB.
One key point I was trying to make about stringers is that they are dangerous. They will cut you but more importantly, if they catch your hand or arm and then they wrap around the work then they can pull you into the lathe. If you have a big nest of stringers, stop the lathe and clear them. Please don't get hurt.
I'm glad the tool is making your work easier and more accurate. I've been criticized before about the angles on my tools. Some experienced guys say the angles are too much. I grind them this way because it works better for me - roughs better, sizes easier and finishes far more accurately. In the end, that is what counts.
Yeah, try to hone until there is no light reflecting off your edges. A sharp tool will cut quite a bit of stock before it needs honing. Hang in there, HB; it will come.
