- Dec 18, 2019
- 7,681
I'm in awe of your work. You have done some pretty cool stuff. It would be awesome to convert to ELS. My mini-lathe has the same identical gearing and lead screw.If your mini-lathe is similar to mine, the feed rate is 1/256 of the spindle speed. That is about 0.004"/rev. This is calculated as (20/80) * (20/80) * (1/16) = 1/256. The 20/80 reduction is from the gear train and the 1/16 is from the lead screw pitch. Beware that this is for my Micro-Mark Tru-Inch mini-lathe, yours might be slightly different. But, you can do the same calculation.
I converted to Clough42's ELS system. Now, I can dial in 0.001"/rev up to 0.040"/rev. The ELS gives you RPMs as well. You might want to consider doing this conversion as you can change the feed rate as you are turning. This makes it easy to turn to a shoulder by slowing the feed rate as the cut nears the end. Also, you get metric threading for free!
I'm still learning to grind my HSS lathe bits. I found the belt grinder orders of magnitude easier than a bench grinder. It's vastly faster and cooler and you get flat faces. My turning improved a lot by getting and keeping the faces polished by honing. It's makes a big difference. I can take take 0.040" DOC in steel now. Before I was taking between 0.005" and 0.010" DOC.
Agree that using a belt grinder is lots easier. My belt grinder is sub par, so I'll end up making one of my own. It's on the "projects I'd like to do this year" list. I have limited access on one side of the belt which makes it hard. So for my new grinder I need to make a table that is omni-directional.
I'd love to be able to do 0.040 DOC in steel, but I'm not there yet.
