Models for grinding HSS Lathe Tools
So what would you say a much smaller radius for the tip of the tool to keep that finish?
His nose radius is already pretty small. Tim is using the end edge to shear the cut; see the shaving? That is what you get when using the end edge just behind the nose radius, a shearing cut. This produces a nice finish in almost all materials and can be especially effective with light passes.
Hello everyone,
I have been having trouble with 2 pre-cut HSS tools after cutting some alu 6061 : one is dulled and one is broken and poor regrind was tried on it.
The offset cutter, I can try replicate the grind with the intact left hand.
The turning cutter looks not very ground.
My bench grinder is a brand new Dewalt 6-inch.
My pictures
Do you have diamond cards to re hone the edges instead of grinding? Did this work well when you were cutting?
Sadly not, I only have one combination india stone. Which grit I should get for the diamond card ?
They were working fine before I pushed too far at cutting alu.
I can say the cards Aukai suggested work good i have a set of them. I also pick up the ezelap sticks and get them today.
Find a good lapping oil too to keep the cards clean while in use. I use Trend, but it is said to be expensive, and other light oils can be used but I cannot comment on how good that is..
Seems to be expensive, indeed. I'll start looking around for this such oil.
