Mikey et al,
Here is the tool intended for cutting ebonite and other soft materials, per our discussion in posts 1503 and 1504. 15 deg side and end relief, 17-18 deg back rake, and 20 deg side rake. Took awhile to remove all the rake material. The shining at the edges is from honing flat vs the curved grinding wheel. Yes there is one facet in the northwest corner of the top, but I didn't want to risk the rest of the cut to clean that off. And yes there are a couple of nicks on the edges behind the top. They annoyed me too, my bad.
It's incredibly sharp.
I'll try to take a test cut this tomorrow.
Curious about your and others' thoughts.
Tim, I forgot to mention that you need to put a small nose radius on this tool.
It is clear that something has happened to greatly improve your tool grinding. I think you mentioned the grinding wheel might have helped a lot but whatever it is, you have come a long way, Sir!
