Wouldnt a thicker blade make a bigger cutting force as well though? I have to grind another cut off blade so i can maybe make the blade .100 thick? And i will make the cutting tip straight across not at an angle. Should i put a rake on the cutter? Anything else to help the profile? Of i gotta cut a part off and flip it over to clean it up then well thats what i have to do.
The tool post i have now i can only take 3/16 bits. I can fit a 1/4 in but then i have to grind alot off the top to get the bit on center. I am getting a new tool post set up made from Tom and he said he could fit 3/16 and i think a little bigger. I will do a little digging to see if i can find an adjustable parting blade like they have. I can only use hss i believe on this lathe so ill see how the adventure goes. Thanks for the help.
