- Dec 20, 2012
- 9,408
I don't know what the other guys think but I can give you my take on a flycutter tool. I used to grind a left hand roughing shape with a fairly generous nose radius - slightly larger than 1/32". I wasn't too deep into tool modifying back then but I wasn't too thrilled about tool life, although the finish was really good. When doing harder materials, I could go through three tool bits just squaring a work piece made of stainless steel. Then I discovered Sherline's inserted carbide flycutter that had a much longer work life and never looked back.
Knowing what I know now, here is what I would try if I were to grind a flycutter bit:
Dunno' ... what do you think? Why not make a LH square tool and try it, then report back and we can brainstorm on it.
- Almost every cut will be an interrupted cut so I would only use M2 HSS; cheaper, more impact-resistant, fast to grind.
- For a shape, I would grind a roughing tool shape or possibly a general purpose shape like our square tool. Depending on depth of cut, cutting loads may be very high.
- Flycutters run at high speed, which lowers cutting forces so we can afford to keep relief angles near baseline levels for strength.
- Since the relief angles are stronger, we could afford to increase side rake to boost chip clearance and lower forces more so I would go maybe 4 degrees above baseline.
- Almost all cutting is at the tip so I would boost back rake by 5 degrees and this will put all the cutting action at the tip.
- Then I would grind a nose radius just a tad bigger than 1/32".
