Looks good to me, Mike, except the top needs to be honed a bit more. See that bright edge along the rim? That means the relief angles underneath and the top surface are not making a clean intersection. Just hone it until that bright edge is gone and it will be sharp.
Remember that a form tool has a huge area of engagement so you have to run the lathe slower and feed carefully. By that, I mean you need to run really slow and make sure you feed fast enough to keep the tool cutting constantly. As you go deeper, cutting forces increase dramatically because more of the edge in engaged and you may need to slow down even more. Much depends on what you're cutting into but if you get the speed and feed right, it should go okay.
