- Dec 20, 2012
- 9,422
I just finished restoring a Sherline lathe and the owner used it for the very first time today. I let him try my old square tool that needs regrinding; must be at least 10-12 years old and has lost most of its back rake to honing. He was cutting 12L14 and it blew his mind when he took a 0.050" depth of cut (0.100" off the diameter) at 1200 rpm; cut like butter! Pretty sure we could have gone much deeper but he wanted to try lighter cuts. Then he took off a thou, and then he interpolated and took a 0.0001" depth of cut to produce a steel wool ball made of angel hair that just about floated into the trash bin. He is now convinced that the right tool really does make a difference.
I've said it before. A good tool will take as big a cut as your lathe can handle, then turn around and take a micro cut to bring you in dead on size without you even noticing it. Trust me, guys; this tool grinding thing is a skill well worth learning!
