I ran a few test beads this morning. It looks like it's all working as it should.
They are done with an oval weave on the same grinder brushed piece of angle.
I see a little of the contamination, but I didn't want to grind to keep the conditions the same on both tests.
First bead is top left, going down on subsequent welds. Then across to the right and down.
No cratering at the ends of the welds. I backed up just a little at the ends.
I ran amperage and feed recommended on the chart on the machine, 6-60 with about 1/2" stick out.
I tried 5-50 on the last 6 beads and I don't see any difference. Gas was set at 19 CFH.
They look pretty good to me.
