- Mar 31, 2023
- 21
That would make it permanent. That is why i don't want to use adhesives so i can dissasemble it after if needed.I would drill & tap the rods and install threaded studs, like in the cam drawing, then drill & tap slightly larger mating hols in the rotor grooves, fill the holes with epoxy or JB Weld and press the rod stud assembly into the grooves. Once the epoxy sets it will never come apart.
The plugs as stated above would make it permanent (or at least needing to drill out the plugs if you want to dissassemble it). And both the outer rotor surface and the rod surface is critical to be "airtight", that is why i dont want external holes. And that is why i will be using ground bars as stock for both the rods and the rotor part.You five pins. The spacing on the rotor allows for fasteners to be drilled and tapped from the far side. Just cross drill the holes and tap the rods just like your drawing. If you can't have an exposed hole on the rotor, just plug after fastening the rods.
How do i make sure the dovetails pull the rods tightly into the groves? I'm doubting that i can keep the tolerances so tight that it will be a interference fit on my benchtop mill. Or how do you even measure the wedge part of the dovetail to see how close you are?Cut dovetails in the rods and mating dovetails in the core Tapped hole on the end that intersect both the core and the rods will prevent sliding out. Alternatively, an interference fit or Loctite..
