- Mar 26, 2014
- 1,593
A few week ago I picked up an old Ottawa hit and miss drag saw. Been tinkering with it. The crankshaft is all wallowed out where the overriding clutch is and the Woodruff key has been worn to unusable.
My plan was to preheat and weld up the wallowed out shaft and weld up the key way, and Center. Mount it in the lathe in the four jaw and support it with a steady rest . Re drill the Center and then turn between centres to the right dimension and cut a new key slot in the mill.
Before I started I put the crank between centers just to check. It is out 70 thousands on the bearing journals From the ends of the crank. The crank is about 24” long with about 8” of shaft at each end for the cast pulley and overriding clutch on the other end.
If I mount it in the 4 jaw I can get one journal with no run out, but the other one is .037”
What is the proper way to measure this? How do you check for out of round journals?What are my options for straightening this? Will I need to pour new Babbitt bearings? The Babbitt looks fine., so do the journals.
Its 102 years old and it looks as if it’s had a hard life. Someone has welded the one counter weight on the crank. The piston has a broken Wrist pin casting, which I haven’t even got to yet.
Any and all suggestions are appreciated. Thanks
Cheers Martin
Cheers Martin
