I have made two major changes to the engine starting with the distributor.
I decided to try to close up the gaps the spark had to jump to get to the plug. The way it was made the spark had to jump over 0,050 in two places and then still have enough pep left to fire the spark plug.
This picture shows the rotor with the new copper wiper I installed that is 0.040 higher than the original. The bent up staple (that's what it looks like) was the original wiper and it was in bedded down in the plastic.
The spark now has a combined jump of 0.020 not 0.100 to make before the spark plug. Miss fires are a thing of the past.
The next change was the flywheel and as Robert had questioned earlier there was not enough mass for smooth running.
The new flywheel weighs over twice as much as the original and about the same diameter. You may ask why didn't I just go to a larger diameter and the answer is this is the only piece I had.
The engine doesn't like to run below 1200 rpms as there is a problem with the fuel distribution to the cylinders. Cylinder #1 is running too rich and cylinder #4 is running too lean. I will be investigating this issue in the future and I believe it has something to do with intake manifold.
I am not very good at taking videos so be kind.
Thanks for looking
Ray
