Making a Part Look Pretty
A buffing wheel can be an important tool also if you are looking for a shiny finish, especially on aluminum.
That shell mill is what comes with the hf and other mills and it is okay for some work but not much.
For flat surfaces, you can sand/lap the surfaces using progressively finer wet/dry sandpaper then grades of scotchbrite pads. Rub the part in figure 8 pattern and machining marks will quickly disappear. Use a piece of glass or cheap 9x12 granite surface plate as the flat surface you tape the abrasive paper or scotchbrite to. You can get close to a mirror finish this way. For round parts, finish with emory cloth then scotchbrite in the lathe. A 1x42 belt sander with scotchbrite belt is also a great finishing tool.
