- Mar 3, 2014
- 634
I made a straight edge and finished it with a 3/4" wide pull scraper.
This produced a very flat surface without the low spots generated using normal procedures.
I found that the blue had to be very very thin when spreading it on the straight edge or it would give
bad readings and the straight edge wouldn't hold blue because it had no low spots.
Blue had to be applied and carefully spread with each check.
While this allowed some very good finish readings it was slow and not so good for most of the process.
Another member pointed out the flaws in having such a flat tool surface.
Because the straight edge bowed over time it was re-scraped with a rougher surface and is better to use.
The rough surface holds blue and is much faster to use.
Jim
Jim
