- Aug 21, 2023
- 154
Locomobile was an early American manufacture of automobiles. They first made affordable steam cars from 1899 to 1903. Then switched to internal combustion engines. A recently deceased Northern Ohio collector own a first year production 1899 Locomobile.
Here's a picture of a close friend's 1910 Locomobile. That needed a replacement four-speed transmission counter shaft .
1910 Locomobile. Big difference 11 years make...
View Four-Speed gear box. The counter shaft is the left one.
Started with a piece of 4140 pre-heat treated to 32 RC. and turned. Turned down five steps..
Cut three key-way slots.
Machined three brass spacers to seperate the gears
Gears fitted to shaft with freshly made keys...
Press fitted the smallest gear and two bearing to one end of shaft. The shaft is placed with the smallest gear and set of bearing is placed into the transmission housing. Adding the three gears, three spacers, and. Two slightly smaller bearing are then pressed onto the shaft completes the assembly.
