If I were going to do this, what would be the best method for accurately scraping the 45 degree? I think I could get it flat, but what about the accuracy of the angled surface.
Would a 12" allow for printing of larger dovetails?
Please keep in mind that I'm just a hobbyist who barely knows what he's talking about at the best of times. I'm a long way from an expert! Please read all of the following accordingly,
The angle of the bevel on a straightedge isn't important, you just want a narrow enough angle that it clears going into dovetail ways. You only use one side or the other as the flat reference to mark up the ways. You want
both sides of the angle scraped flat because the bulk of the straightedge will interfere with the work in one orientation or the other, but the actual angle just needs to be smaller than the dovetail angle. You only print and scrape one side of the dovetail at a time.
Even the exact angle between the mating dovetails on the work doesn't really matter. Who cares if it's off a degree or two as long as they are mating perfectly and nothing gets tighter or moves off-axis as the table slides? In practice, you usually scrape the moving part to match the fixed part, first getting the fixed geometry right with a straightedge, then bluing up the fixed part to mark up and scrape the moving part.
Getting the actual geometry right for sliding prismatic or dovetail ways is far too complex to write about in a paragraph or three, refer to the Connelly book mentioned above for a full explanation (or if you just need a nap).
Despite my joke above about needing every measuring tool, the absolute best tool to own (I don't, sadly) is the one Richard King's dad designed, the King-Way alignment tool. It's a clever arrangement of precision levels, sliding joints, indicator mounts, and hemispherical and ball feet to assist in measuring any misalignment of machine tools. It's not a mandatory tool, but you'll be cobbling together custom jigs without one.
The King-way was designed with sound kinematic principles. Not every jig I've made has been!
I think I'm replying to multiple people here, but in my opinion, the only truly mandatory metrology tools are a (hopefully calibrated) surface plate, a decent surface-gauge/indicator-stand, a 0.0005"/graduation dial test indicator, and a precision machinist's level (on the order of 0.0005"/12in per graduation). I'd really want to add a 0.0001"/graduation indicator, too, but it's only useful for the particularly persnickety stuff. Other things like feeler-gauges/shim-stock, parallels, 1-2-3 blocks, and jo-blocks/gauge-pins can also come in
very handy.
Lastly: either a 20mm or 25mm blade is fine for scraping flat, unobstructed surfaces. In general, the wider the blade the easier it is to handle, but the more likely you'll have trouble fitting into tight spaces. The compound on a small lathe will require a much narrower tool to get into the dovetail than 20mm. I use a 20mm blade for almost everything, but a 10 or 15mm blade when I need to get into tight spaces. A 10mm blade is
much more difficult to handle well — it's all too easy to tip the blade accidentally and catch a corner. (It's worth rounding the corners of all your blades for exactly this reason.)
The most important tool is your brain and patience. Rich calls it "detective work" for a reason.
