- Nov 14, 2016
- 3,244
Ya know Aaron,I use to consider us friends, Cohorts, Pals even... But now that I see you've been hiding that beautiful horizontal mill, I think its time we revisit our friendship contract. And by that I mean palletize that horizontal mill and send it to me and we can let bygones be bygones, So what do you say Deal...?
You have the best of both worlds right there Sir, Very Nice.
Lol guess I'm asking too much of a single milling machine to be fully multi purpose.
Really there is a huge amount of overlap between horizontal and vertical mills. It is not so much that one can't do something, each is better for doing certain operations. A large vertical mill (Bridgeport etc) does all that most home shops need. When you are dealing with smaller machines though the strengths of each can help overcome the size limitations.
Using my two mills as an example, they are roughly the same class of machine. The Y and Z axis flips between horizontal and vertical mills because of the relation to the spindle.
Clausing 6x24" table, 15-5/8" spindle to table (mine has a 4" spacer block, standard is only 11-5/8"), 11-5/8" travel up and down (Z), 5" travel in and out (Y), 15" side to side (X)
Diamond 5-1/8x20" table, 5-1/2" in and out (Z), 15" travel up and down (Y), 14" side to side (X)
So the two mills are very close in capacity, but since they swap the position of the spindle, they also trade the working area available. The vertical mill is very good for a task like drilling or face milling where it has almost 12" of travel, but is quite limited when working to the side of the spindle (slitting saw, side milling etc) where it only has 5" of travel (minus cutter diameter).
The horizontal is the reverse, it has 15" of travel for work "off the side" of the spindle, but it is not so great for drilling, since it has only 5-1/2" of travel and at most about 10" minus the work thickness "spindle to table". With the spindle held from both ends the horizontal mill is also a fair bit more rigid for many operations.
Combined I essentially have the equal of a mill with 15" Z, 15" Y and 15" X which is like a much bigger mill if I'm thoughtful about the needs of a task. Comparing to a Bridgeport Series 1 with 19" Z, 12" Y and 36" X you can see where somebody with a full size mill, doesn't feel limited doing "horizontal mill work" until they get to really large parts. Of course they do make big horizontal mills for those that need them.
