picked this up a while ago and am about ready to set it up, would anyone have a manual on this model, i want to be sure i hook everything up right
thanks!
Have you checked to see if there is a wiring diagram on the inside of the cover?
If you post some good pictures of the internals (wiring in the box) there are enough people familiar with RPC's around here that we should be able to help you figure it out. RPC wiring is usually very straight forwards.
Is there a female 4 pole twist lock plug receptacle wired into the converter?
The input is single phase ,
generally denoted L1, and L2, and a ground wire
