- Jul 28, 2017
- 2,606
I've found that most of the dimensions on my lathe and milling machine happen to be nice multiples of 1mm. So if I'm making/modifying something and the measurement taken from my machine is, say, 17.95mm I will round it up to 18 with a high degree of confidence it really is 18mm.
Also. Unless absolutely necessary don't drill holes according to their close fit specification. Go with standard fit or (if you really are uncertain about the exact distance) a little more generous than that. I'm not talking about holes that are meant to be tapped, of course.
Transfer screws are a nice thing to have, too. While a set can be expensive you can make your own. I have made a few using socket-head allen screws. Using your lathe drill a hole on the socket end that's a bit smaller than the socket, then insert a sharpened piece of music wire in the hole once you've installed the allen screw. Bring your piece-to-be-drilled up to the one you want to match and tap to mark the desired location of the hole(s). Pull the sharpened bit out with needle-nose pliers and then you can back the allen screw out of the hole, ready for the next time you need it.
These also can be handy for this sort of thing, if you're working with through-holes.
