Ok, I belive the gears are not setup right. I will check and see how they are set and let yall know later today.
Be careful changing gears with the lathe under power. Use your hand to roll the chuck if they won't mesh to be on the safe side.
Jonathan,
If the 60T gear turns when the lathe is running but the feed screw doesn't, then the levers are not set up right or fully engaged. Is this a new lathe or a used one? If used, it's possible that some knucklehead may have run the carriage into the headstock and sheared the pin in the feed screw.
Tom
Jonathan,
The 60T gear is the input to the quick change gearbox. If that is turning then the issue has to be that the levers are not set properly or not fully engaged, unless the shear pin somehow got left out at the factory. Can you see if there is one present in the left end of the feed screw where it enters the QCGB?
Keep at it, you'll figure it out. Sometimes these lathes have unique personalities or quirks and take a while to figure out, kind of like women. :thinking:
Tom
