If your holes are larger than your screw that goes through them,make sure both the upper and lower nuts are well tightened when all is leveled. Seems like the screws could move around in the holes from machine vibration if they aren't good and snug,causing your machine to get out of level.
I need to check my large lathe: we had a small earthquake tremor some months ago here,which never happens around here. Probably I need to re level my lathe to some degree. I used those type pads(I think mine were Masons).
