- Nov 21, 2012
- 793
I do air guns too ha I shoot a steyr lg100 and it will put ten shots in one hole at 10 m if you try I routinely hit in the upper 90s in prone on a 10m rifle target. I've never delt with silencer because most guns I've heard are not too loud but are some so loud that silencers are needed?
Silencers on PCP's make a big difference. On spring air rifles you still have noise from the piston so the suppressor works to some extent but can't quiet the action of the rifle itself.
With a PCP the way the supressor works is very different from that of a powder burner. On a powder burner the suppressor cools the gasses and the need for creating inverse sound waves for cancellation of sound wave forms is secondary to efficient cooling.
On a PCP, the gasses are cold already as per Boyle's law P1V1/T1 = P2V2/T2, where the increase of volume on release of the gas results in a temperature drop and pressure drop. The moderator therefore focuses on volume and and irregular surfaces to create inverted wave forms to cancel out the sound.
Paul.
