- Sep 28, 2013
- 4,399
good tip on the thread handedness, that's an easy one to remember
As to the directions of spindle and lead screw, not so in all cases; The Regal Leblond lathes have left hand lead screws, so when cutting right hand threads, the spindle and lead screws are rotating in opposite directions; why they designed it that way, I have no idea.I wanted to be further along by now but, #3 son called, stranded in a local parking lot with a dead battery. We took care of that without issues.
So, it has a left handed tread now and the nut fits just fine.
Threading Quick Tip: If the chuck and leadscrew are rotating in the same direction, you will cut a right hand thread. If the leadscrew and chuck are spinning in opposite directions, it will cut a left hand thread. It makes no difference what directions they are actually spinning, it only matters which direction relative to each-other.
LOL: When I went to cut these threads, I almost made them RH because... well because I just forgot they needed to be LH. Fortunately, I only got as far an initial scratch to see if the pitch was correct. No harm done. Man, I would have been ticked...
Ray
