Kawasaki 1/2" drill chuck
kelroy
Dec 5, 2011
20
Anyone heard of these? I recieved one with my Atlas 618 purchase. It looks to have a MT2 taper shaft and my tail stock is a MT1. It is a keyless chuck so I would like to use it. I cant seem to get the taper piece to seperate from the chuck. How do you do that???:huh:
Depends......some are taper mount, some are threaded. Look for marks on the chuck body. Either thread spec or Jacobs taper normally. One unscrews, sometimes with a LH screw from the inside to lock it, but the taper locks in pretty good and you should use a pair of wedges made for removal of Jacobs taper mounts.
Can you post a pic and is there any model number makings on it?
I will get pictures of the drill chuck tomorrow and post.
Judging just from what I can see I think the arbor is taper mounted in the chuck and as a previous poster mentioned you'll probably need the correct sized Jacobs wedges to remove it. I see a groove around the arbor near the chuck and that's what leads me to believe that. Someone may speak up with other solutions but I've had to do the same . Is case you've not seen them....I've included this link. These just press in from opposite sides and the chuck (usually) will pop right off.
http://www.jacobschuck.com/product_details.asp?pid=29
That is a 33 Jacobs taper mount (33JT marking). Wedges are the proper way to remove it.
