Just seamed to take too long. For some reason thought I needed 6 pulleys so made six but the good news is I now have spares. The cylinder is fixed using the tie rod bolts, took a lot of buggering to get the plates made, they also act as gussets to the mount arms. The tube that wraps around the pulleys to keep the cable in hit the chute, so I had to make a spacer plate out of polyethylene to go under the chute. Wanted to do that anyway, swivels smoother now. Of course the spacers I'd made to hold the keeper plates up squashed the plastic so I had to make longer ones that went through the plastic. The usual redesign as you go.
Had to buy a piece of 1 1/4 shaft for the auger and the cylinder so far, the rest is recycle Mike.
Probably get a chance to try it Randy, the snow was pretty much all gone but we got a couple inches yesterday and expect we'll get our usual late snow dump. Was a poor winter for the snow mobile though.
Start building bearing mounts for the blower and jack shaft today, Hope they don't require as much redesign.
Greg
