In the past i've used "EZ slide" graphite paint on the underside of mower decks. It works great in that there isn't any build up of grass in the corners that will rot and cause rust. It used to be available at nearly every farm store, but I haven't seen it in the last few years. I have one quart left which I intend to use on the mower deck of my JD 445. One application usually lasts 2 years. Hopefully by the time it's gone I'll find another local source.
Funny you should mention the decals. Charlie and I were looking into it, thought about buying a plotter for cutting custom decals, then looked at the cutter assembly they use and wondered if if could be mounted to the plasma table and make our own plotter.
