- Jul 28, 2017
- 2,599
Some time back I bought a 50VA N-68X Triad isolation transformer and recently encountered a problem that it may solve. I think I have a ground loop via a couple of switching-mode power supplies and it's injecting a lot of 60Hz hum into a headphone power amplifier I designed/built. It isn't ripple on the power outputs because the amp is very quiet when nothing is plugged into its input jacks: and it isn't my phono preamp because I'm not hearing any hum when I connect it up to my laptop. It only shows up when the preamp is plugged into the headphone amp. It may be the chassis-ground connection between the turntable and preamp, but that connection MUST be there to keep hum out of the preamp.
Ohming-out the power supply outputs revealed a capacitor-like signature between the output pins and the earth ground on the 3-wire power plugs, so that is another reason to suspect a ground loop issue. The ohmmeter momentarily shows a low resistance value that quickly rises into the megohm range, pretty typical for a decent sized capacitor.
The N-68X is a bare isolation transformer so needs power connectors on either side. The input side has three wires: two for the AC, and one for an internal shield: and that's my question. How is that shield connected? Is it connected to the input earth ground? The cold side of the input line? The "earth ground" line on the output's 3-wire power connector?
