@alloy,
I'm concerned that because of the very shallow current drive shaft angle, when you pitch the pinion shaft up, you may find that the pinion shaft is higher than the trans yoke. I'm almost certain that it will be.
What would prevent you from raising the back of the transmission? Could you raise the trans tail shaft to get zero degrees incline on the trans?
That way you will only have to put a 2.2° shim on the rear end and you will get a closer to 3° drive shaft angle
I also feel that the pinion may wind up a little higher than the tailshaft... but I can't think of a reason why that would be an issue as long as the u-joint angles are within reason...
Just curious... how did you compute the 3 degrees for the driveshaft? I've been trying to figure that out, but I keep thinking that I would have to know the length of the driveshaft to determine that...
-Bear
I mean it this time!See you boys tomorrow!
