- Mar 26, 2018
- 8,716
The fact that I've never turned a single sheave pulley shouldn't deter me from this project.
I do have it's opposite for dimensions.
This is for my 1930's (Canedy-Otto, Royal 16- by Cincinnati lathe and tool) drill press.
My thoughts on how to begin.
1. Drill and bore 6" material to spec.
2. Cut to length.
3. Mount on the arbor I had previously turned for concentricity, face both sides to final length. ( I'm turning between centers.)
4. Cut the taper-shape the cone..
5. Using a parting/grooving tool, plunge to sheave depth.
6. set compound to desired angle and cut half of the first sheave. Change to the opposite angle to finish the taper.
7. Move over designated length, lock the apron each time, plunge to final depth. Rinse and repeat.
I am working from smallest to largest.
Please critique my thought process. Go ahead, giggle and point out my mistakes. I can take it.
Thank you,
Jeff
2. Cut to length.
Thank you,
Jeff
