I was sorting all my 1/4" driver bits and found a couple that are very similar to a Phillips bit.
Instead of being marked P1 or PH1 like my Phillips bits, they are marked PBR2. I know they are not JIS or Pozi bits.
In the photo you can see that the PBR bit on the left has the same shaft size and slot sizes as the PH1 on the right. However it has a flat tip and the slots/groves go much farther past the taper than on the Phillips bit.
Can anyone identify the PBR bit?
