- Jul 4, 2023
- 9
Short version (to the best of my ability):
I am always looking for ways to increase rigidity and remove vibration in my machine to get the best possible cuts on my CNC router, especially when cutting clear acrylic parts. The machines main bed is a large few sections of aluminum T-slots with covers on the front and back and measure roughly 51" long. I finally undid the front cover to see what I am really working with and see this:
Here is my question and I have finally learned the lesson: its better to ask before spending the money on potential upgrades before understanding whether or not this will be a good idea or not.
Idea:
I want to fill the hollow interior of these aluminum T-slots with Epoxy Granite (20% epoxy, 80% sand) as I have recently learned what it is and how it has great anti-vibration qualities to it as well as making the machine heavier. I am also entertaining the idea of filling the welded steel table base its mounted to with sand or epoxy granite as well to get rid of any and all chatter caused by the gantry just not being up-to-snuff.
My initial thoughts:
I have never used epoxy granite. I have seen people fill older manual mills with epoxy granite with success so this is what got me thinking about this. I am slightly worried that the added weight may cause some bowing in the center of the machines table as the linear ways for the Y axis are mounted to the bottom of the T-slots.
I am a TOTAL sucker for tuning my machines to work even better than they initially arrive to my shop. I understand the manufacturers that make these machines have the burden of finding solutions to make their machines both economical and functional to the best of their ability so it always seems to me there is room for improvement with these machines if you have a decent understanding of the many different things available to you. Epoxy is pricey, sand is cheap, mix the too and this idea would probably be at or under $100 so I figured its worth its weight (pun intended) in functionality if it works even marginally.
So the question is: Am I crazy or...?
Idea:
