I could really use some advice about making a part...
Hi Guys,
I agree with Bob !
I wanted a 45 degree bevel gear and I had one on the shaft from an angle drive. It turned out that I couldn't get it off the shaft. It was molded around a flattened section, it broke in two when I tried to press it off. That was magnetic and looked like steel.
I had thought that it was on a spline ! I drilled shaft out of the other one on the lathe.
I honestly don't know. I have drilled into cast iron once before several years ago. I remembered it was easy to drill but I sure thought it made curls as the drill bit was cutting it...but it was a long time ago and I'm not 100% sure of that.
Powdered
Depends on the type of cast iron. There are many types, and with different qualities. Ductile cast iron, for one example, makes curly chips, and is stronger than many steels, in some ways.
