- Sep 22, 2010
- 898
Hey
At least you had the courage to talk about it, how many would have suffered in silent shame?
Glad it was a simlpe fix. they often are.
I worked on an industrail food packaging machine the other day where the key had slipped out of the keyslot and was bouncing around inside the rubber coupling. My guess is that at the factory when they tightened up the set screw they did not make sure it was resting on the key, so the key was free to slide in the slot. Took a few hours to get to the vacuum pump, get the motor off the pump and get it back together, but worked fine after that. Tell tale sign, the shaft for the pump did not turn even though the motor was running.
Walter
Walter
