the pressure should bleed off every time the compressor stops
What is bleeding off?
Is there a check valve somewhere that may be inoperative?
Why does the new valve bleed off the whole time?
There should be a short burst of air exhausted after the compressor comes to the high pressure cut outWhat is bleeding off?
Ah Ha!If air comes out of this valve for more than about 5 seconds after the compressor shuts off, then your check valve ( usually located where the air line from the cylinder head enters the tank) is leaking. These can often be removed and cleaned and will work again.
Hang in there, you will have a new compressor by the time we are done with you... you will have just purchased it one part at a time though!Ah Ha!
There is a check valve. Missed it the first go round.
Thanks guys, that's next.
