That can be a symptom of a non-functioning unloader valve. Take the cover off the switch and watch the operation of the valve, make sure the pin is being pressed down when the switch shuts off. It's possible it got tweaked when you tightened the air line fittings. If it was work fine before you changed the switch that would be the first thing to check.
