- Feb 28, 2019
- 537
Went down the path of trying out "blueing" steel. Finally settled on just heat and dip in canola oil multiple times. I use my muffle/heat treat oven. Give it a good soak depending on size. Don't recall the temp off the top of my head, but think it was in the range of 600-800 F.The coating is black oxide, @benmychree describes the classic process. There are several others that operate at lower temperatures.
Here's the one I've used recently.
This method is simple, takes some time and doesn't involve storing and handling chemicals. Nothing against the other methods, but this worked great for me on hot rolled steel.
