Does anyone know how to get this gray finish onto steel? I really like it and can’t figure out what process was used to achieve it. I put a standard chrome for reference.
Nitre salts, Brownell's sells them. It's dark and blue-black. Ospho rust is a phosphate pickle, it makes a nice gray color that holds oil for rust protection. Manganese parkerizing is another option (also Brownells) that is gray to black and long lasting.
I used the Rusteoleum version of Evaprust on a Walker Turner drill press. It turned all the surfaces rough gray and I did not want it gray. No amount of oil will make it slick.
Rustoleum rust dissolver is phosphoric acid with some chromium conversion capacity. If you warm the solution, add a few grams of potassium nitrate, and mix in manganese phosphate (the black outer core of a dead D cell battery), you'll have a blackening solution.
Half and half mixture of sodium and potassium nitrate, with a small occasional dose of manganese dioxide to clean up the bath, operate the bath at 600 - 650 deg F, coat the articles with a thin oil and immerse small articles for about 5 minutes in the bath; this creates a rust resistant blue to black color coating.
This is from the U.S. Armory
The coating is black oxide, @benmychree describes the classic process. There are several others that operate at lower temperatures.
Here's the one I've used recently.
Now that you mention it... But that was just some of what I gleaned from the methods described obfuscated by patent-legalese and utterly buried in this illuminating document: https://patents.google.com/patent/EP0977908B1/en
