- Nov 24, 2013
- 1,791
Your not grinding on the surface of the wheel. Just the leading edge.As you advance the part and that edge is used up the portion just behind the leading edge becomes the new edge so to speak. If you wer grinding on the whole flat it would take seconds before the wheel was no longer touching as you burnt off the "cutting surface".
I believe Mr Wilson's point was not that they would not mic the same off the machine. But rather, the sharper taller peaks from the lathe would wear very fast (provided something is wearing on it) thus leaving you .0001 or what have you, under the desired size.
First of all, congratulations on figuring out that trick. That is something a person would normally learn at the elbow of a master machinist and you came up with it yourself. Nice
Grinders definitely create a very fine finish. I don't beleive that, in itself, gives a ground finish any better dimensional accuracy though. Think of the finish as a peaks and valley on the surface of the part. Whether you are talking about a lathe finish of 125 microinches (pretty darn rough) or a ground finish of 10 microinches (pretty darn nice finish) you are still doing your measuring on the peaks of that finish. The very fine tolerances come from the very fine cutting tools (grit of the grinding wheel), the wide contact with the part for even pressure dispersal, the rapidly rotating cutting tools (which makes the grinding wheel essentially one wide tool instead of thousands of tiny tools) and the very fine advance of the grinding wheel usually in the range of ten millionths to a hundred millionths (.000010 to .000100).
Just my two cents,
David H.
