- Jul 26, 2011
- 4,142
Setting the compound at an angle has long been standard operating procedure for working to very fine tolerances. The thing IS,a cut surface will really be too rough to really,truly be accurate to a .0001". You need to grind the surface to truly get the surface smooth enough to be at that tolerance. Otherwise,as soon as the turned surface gets the microscopic "fuzz" worn down,it will no longer be at that accurate a diameter.
So,the answer is,set the compound to an angle and use a toolpost grinder to achieve this close a tolerance.
However,then the problem of how good your spindle bearings are raises its head. You have to have a high quality lathe with high grade bearings to have the piece truly round to that tolerance. When I had an Atlas lathe,my grinding came out looking like the wild grain pattern on plywood. The spindle bearings,and the rigidity of the lathe just were not up to the task.
When I got my first Jet lathe,a 10" x 24",the difference was night and day. And,that was still a low cost lathe. My current lathe,a Hardinge HLVH has high grade spindle bearings accurate to 50 millionths,and a very thick,heavy bed. This lathe can actually work to that tolerance.
I had fun experimenting with tolerances too,when starting out. Keep experimenting,and you will increase your knowledge and figure out new ways to do things.
