So I think I have discovered the problem.. but I don't know what the cause is... Watch this video...
This seems like a classic case of a motor wired for 220 running on 110. I've heard of this a bunch, and encountered it myself on a jointer I had purchased. In fact miswiring contributes to machines being sold cheap, it must be an easy mistake to make. You just never know what the previous owner has been up to , or what their skill level was.Well, I hadn't even considered this but I don't know how else one would get 1/2 of line voltage with the motor running other than that if it is wired for 220 VAC instead of for 110 (if the motor were made today it would say 240 and 120). That would certainly explain why it has almost no power. Post a photo (not a video) of the motor's wiring diagram plate and of the drum switch's connection diagram for 110 VAC single phase reversing.
Or if you feel that you know what you are doing, disconnect all of the motor, drum switch and line cord wiring and reconnect them for 120 VAC single phase, not 240. Or as the plates will be marked because of when the motor and switch were made, 110 VAC instead of 220 VAC.
Tim
There are jumpers inside the motor that allow you to run the motor either on 110 or 220.. the switch also has to be changed over from one to the other.. I think what has happened in my case is that someone has changed either the motor or the switch. and not the other...I’m sorry. Can someone explain how one would go about wiring a 110V motor as 220v? This seems inconceivable to me.
My solution, since it comes off of the machine as one assembly if you will, is too take it too a electric motor shop and ask them to have a look at it. I don't want it to cause a fire and I don't want it to burn up the motor...
