Speaking of bushings, if for any reason, you ever decide that you need to pull the spindle, DO plan to replace the three bushings. Two are in the spindle cone pulley and one is in the small spindle back gear (the one keyed to the cone pulley).
Also, maybe 5% of the 10" and 12" lathes that turn up here had a previous owner who thought that the oil plug in the spindle cone pulley was a set screw and managed to force it down against the spindle. In back gear, the spindle cone pulley turns about 6 times as fast as the spindle. So don''t make that mistake. The oil plug is removed either daily, before using back gear or at least Monthly if you haven't used back gear and several squirts of SAE 20 non-detergent oil but down the hole, and then the oil plug replaced. Do not over-tighten.
And what "upgrades" are you referring to?.
And I am considering just go ahead purchasing the new bronze cross feed and compound nuts.. I think my lathe needs a new cross feed as it has almost half a turn of the knob in backlash.. and the compound has about a 1/4 turn of back lash…. I may need a new cross slide screw as well..Speaking of bushings, if for any reason, you ever decide that you need to pull the spindle, DO plan to replace the three bushings. Two are in the spindle cone pulley and one is in the small spindle back gear (the one keyed to the cone pulley).
I saw that.. and I am not sure that I am going to need to cut 4 threads per inch any time soon.. LOL.. but I did see that.. and thanks for mentioning it.. I am not going to do anything that can't be undone...Regarding the feed reduction hack of substituting the 24-tooth gear.... The YouTube videos don't make this clear, but you will lose the top two rows of threads on the threading chart. So you will need to change back to the original gear when you want to cut those threads. No big deal, but something to keep in mind.
