It will actually draw the motor down to a stop.. and the belts are not slipping.. I mean there is always some amount of minor slip that you really can't detect in all belt driven tools... but since it will draw the motor down to a dead stop.. the belts are not the issue.. What happens as these motors get older??? Do they lose some of their horsepower?? And no. this is wired into a standard wall outlet that we wired using code approved wiring..Something is wrong. Mine has plenty of guts with the original Atlas 1/2 hp motor running on 110 V.
Does your motor actually slow down and/or stall? It is not that a belt is slipping?
You are not powering it through a 100' long 18 AWG extension cord, correct?
Now.. This Atlas is running on 110V.. but it really has NO GUTS... I can not do much more than a 3 thousands cuts, even on Cast Iron.. It has the original Atlas motor which is 220V Capable.. what do I need to do to switch this lathe over to 220V... And will that help my situation?? HELP!!
I am trying to turn down a lathe chuck adapter for my 4 jaw chuck.. it is cast iron, so it should be fairly soft.. I am using insert tooling with new inserts and the tool height has been checked. I have a QCT that appears to be solid. I CAN NOT even think about using auto feed because it literally stops the motor. I touched off.. and then turned in less than a quarter turn on the cross slide.. and it will bog the motor down almost instantly when the tool touches the work.. you can hear it drag the motor down...Yeah, voltage isn’t the problem. You should be able to take .020-.030 no problem.
Rigidity in your ways and tool post, belt slippage, tool alignment, tool geometry and proper sharpening have a really big impact on depth of cut.
Once you have confirmed all is good there is speeds and feeds that matter as well.
Of course another member mentioned voltage drop, but I doubt that is what is happening given that it looks like you have power in your shop close nearby to your lathe.
